Anyone try diagonal connections on your speakers?
I wired my speakers for years with red to the bass and black to the satellite section. When I checked my newish Legacy Focus SEs, they were wired to the bass section only. So I swapped the jumper and speaker lead on the black (-) side and listened for a while. And I did not like it at all. Sure the soundstage was bigger but it was screwing with phasing. As in, the center image was no longer as strong. I also watched some programming on TV that I watch every morning. It almost sounded out of phase. Normally, I can’t really tell if the center channel speaker is on or not. With the wires crossed, it was totally obvious the sound was coming from the mains and unfocused at that. I didn’t touch the red (+) leads, so I know for a fact, the speakers were in phase. So I put it back and much prefer the sound of things with both leads going to the bass section. For reference, I run an Ayre stack (KX/VX-5 Twenties) to the Focus speakers. My speaker wire is Audio Sensibility Statement with Statement jumpers.
I’ve learned to snug them up as well including the external driver fasteners as needed. Usually once a year or so.
As I stated above, I recently tried connecting my speaker wires diagonally again and after almost a week, I switched back to wiring the speaker cables to the LF inputs and using quality jumpers to connect to HF.
I originally got impressive sound connecting diagonally, but over time, after checking different recordings I know well, I found the sound odd at times, harsh at others, or light on bass. That is on quality recordings that never had this in my previous configuration (connecting speaker wires to LF and jumping to HF) so I switched back.
I’ve actually experimented with diagonal speaker connections, and I must say, I’ve been quite pleased with the results.
I highly recommend giving it a try if you’re looking to fine-tune your speaker setup. The difference may surprise you, just as it did for me.
I don’t understand what you mean by diagonal connections. If you mean that with two sets of binding posts you connect say bass + to treble - and vice versa you’ll end up putting the treble out of phase with the bass.
EDIT - sorry, I should have read the initial post before posting!
This rings a bell. I once studied what this meant. I can’t remember it at the moment? Please explain.
Sounds like trouble waiting to happen…maybe a short perhaps…
hmmm
Best wsishes
picture in post #4 explains it. No shorts.
Diagonal biwire is what Nordost recommends, and I used that method when I was in that tribe.
Now I’m all in on Synergistic Research and they go with amp to tweeters and then links to the bass. I haven’t yet tried diagonal biwire with the SR cables.
I have Fyne F703s which have ground terminals, and darn it if it didn’t make a significant difference connected to my SR Active Ground Block SE.
Kwazy!
