Frode
              1
              Will there be a way to add attachments from iPad (IOS 7)?
It is not possible to drag & drop files or pick files from the local image store on the iPad, which is annoying, to say the least.
Via a Mac OS this is not a problem, it is only via IOS I have problems.
Yes I agree this is a big deal, all I use for forum reads is an I Pad .
                Paul
              3
              I’ll check with the programmers but it sounds like maybe that’s an issue outside the forums? Can you do it on other forums?
                Frode
              4
Paul McGowan said
 I'll check with the programmers but it sounds like maybe that's an issue outside the forums? Can you do it on other forums?
Yes.
The previous one (Vanilla) could do it.
A few weeks ago I thought I saw a Simple:Press setting ‘Optimized for tablet’ (or something similar).
I cannot find this anymore. Maybe this setting would help?
