Audio Equipment and Speaker Set-up Tool
My new favorite audio equipment and speaker set-up tool: I found the Winbag wedge tool while picking up paint at Home Depot a month ago. I thought it was interesting, so I picked up a small 300# capacity one and the larger 500# capacity one. I had no real use for them at the time. They were not designed for audio or lifting per say, but work.
BTW: I have no affiliation with either WInbag or HD. These are available on Amazon, as well some made by other manufactures.
I needed to reposition a sub stack which weighed about 300#, change footers on a pair of speakers and install a piece of equipment into my audio rack. Moving the subs and speakers is often a 2-man job, but I was able to work alone safely and efficiently with these since it freed up both hands. I could easily inflate the bag with one hand no matter how heavy the equipment. I was able to lift the subs high enough to install sliders so they could now be moved on the carpet.
I was able to position the Isoacoustics footers perfectly in a narrow rack now that I did not have to work on lifting the equipment and positioning the footers at the same time. I did not have to worry about scratching, chipping, or denting the surface of the equipment, due to the Winbags smooth plastic material. (See pictures below)
I hope you too may find these of use. Happy listening.
I came across these recently also. They looked useful for any number of things so I bought a set.
My BHK 250 amp sits on a powerbase, and the combination had not been moved for several years. Last week I wanted to reposition it but was quite sure that the footers were stuck to the floor. I used one of these airbag gizmos on either side of the powerbase. When I inflated the first one, there was a noticeable pop as the footers came loose. I’m not sure how I would have done this without damaging the powerbase if I hadn’t had these.
Sold!
Going to find one appropriate for the Hi-Fi components. This could eliminate a lot of the futzing around when trying to places footers.
Thanks for the tip.
Brilliant tip! I’m going to add this to my arsenal.
I’ve found the Dewalt mini jack to be invaluable. For example, adding isoacoustic feet to my FR20’s was a breeze.
I use the dewalt one too. But for tight rack spaces, I think this bag thing is better. I have to grab one.
