PS Audio Speaker Footer Sliders at Axpona
Anyone know what the things under the speakers at Axpona are and if they work well for sliding speakers etc. around on carpet?
Those speaker sliders are packed with the Aspen speakers. They work as intended to get the right spot, then their spikes or another other footer is installed.
They come with the speakers and are intended to help move the speakers while you find the right position for them. I’m not aware of them being sold separately and they are probably provided by the third party that makes/assembles the speakers in China.
Wow, now that is customer service. I gone to have to ask where they get them I would like some for my rack
I did not get sliders with the FR10’s - they must be for the heavier 20s or 30s.
If I remember correctly the discs have integral 8mm bolts for the Aspen speaker stands. I don’t know if they would fit your rack.
JT
Can’t you just get what you’re looking for from Herbie if you know the thread size you need?
I just use furniture sliders under my spiked feet on my FR20s and heavier speakers before these. It’s very easy to lift the speakers and position the sliders for moving, and then remove the sliders when finished moving.
Yeah I saw them online, put some in my cart I have to check thread size on my Solidsteel rack
