Paul McGowan said
Allan,
You’re suggesting that changing the Audio Midi sample rate to 352K did the trick of getting sound? That’s news to me.
For those having this issue, can you try this? On the Mac, got to Finder->Applications->Utilities->Audio Midi and set the sample rate at 352K
I would be excited to know.
I have tried the 352.8 thing off and on since it was suggested (last weekend maybe?) and it has not helped - until now.
In this case, the Mini was shut down, so I hooked the LR up, booted, set AMidi to 352, went into Roon and selected my prior config for LR, and it ‘played’ without sound. Reset the settings in that Roon config to defaults, no go. Reset to the settings I’ve been using, and in AMidi the PS Audio output config disappeared for a few seconds and it defaulted to Built-In Output. PS Audio reapppeared in AMidi, and it now is playing out, though the AMidi output did not change (stayed on Built-In).
I’m doing all this in Screens (headless Mini). So I go to my iPad which I use as Roon Remote, and the functioning zone does not appear as an option. Going into Settings/Audio, it’s there, and appears as does any other enabled zone. So I tried saving those settings, and a disable/enable, and when I click “Enable”, Roon hangs on the “Enabling…” logo animation indefinitely (have waited minutes on other occasions to no avail).
So now I am able to play through the LR in my preferred config for the first time in 9 days - as long as I control it with Screens directly. Take that back, the second time - it worked when I first hooked it up a week ago Thursday for less than a minute. This is not the first time I have had some or all of these behaviors. Now I’ll see if I can take it out and do it again.
a25105 said :
Paul, I have a feeling this is a compatibility issue between the Mac Mini and certain DACs. I agree that does not make sense but it worked for me. That’s the only way for me to get sound between MM, LR & my DAC. However, I still have not figure out how to get sound if I use Bit Perfect with itunes AND LR.
I’ve gotten it to work and/or not work with different DACs and computers. That is, for example, I couldn’t get it to work with the Mini and the Oppo HA-2 headphone amp/DAC, but it also did not work with my laptop and the Oppo (though in both cases the Oppo works with my current GIUSB chain). If I put the Roon Core on my laptop or Mac Pro, the LR works with Roon. I could go on (and have ; ).
So I’m still thinking it is SOMETHING (for me anyway) in the combination of the Mini/Roon/LR.
Prior to this, the only other time I got the LR to work with this specific chain was by using HQ Player! Go figure! I guess that, like Bit Perfect, it takes control of the USB output, and that helps matters somehow.
