I have a Mac mini dedicated to music with bitperfect running on it. It’s set to never go to sleep or shut off. I use the iTunes Remote app on my phone to control the music. I usually listen at night before going to sleep. When I come back to listen the following night, bitperfect is no longer running and I have to log in and start it up. Is this normal? Is there a way to keep bitperfect running constantly?
I have the same problem. I like to play background music sometimes. I’m using an iPad.
Sometimes iTunes pauses and sometimes Bitperfect exits. Sometimes both. I have to hit play and/or launch Bitperfect. Is there a setting in either program that allows indefinite play?
