just got Bridge 2 for my DS, exciting about it.
I use a crossover cable to connect Bridge 2 to a Mac, firmware on bridge 2 shows 2.1.1 and “N/A” from firmware update option. If the crossover cable prevents internet connection how could I update firmware to 2.1.3?
Thanks for help.
wijber
January 14, 2017, 4:41pm
2
Connecting the Bridge straight to the internet (router) and do a full reboot of the DS probably solves your issue
I got the Zip file from Dennis for manual updating
efete
February 10, 2017, 12:01pm
4
I think I am in exactly the same predicament.
Dennis -would you be so kind and send it also to me at troiani@ciudad.com.ar if at all possible please?
dear all I’m in the same situation and I cannot solve the issue. could you please help me? lucacelli@hotmail.it
I downloaded a zip from website but when I open it there is only one file inside *.ub
I follow same procedure as for DSD but it doesn t work. please help
