I’m How To Update Bridge II – PS Audio updating from My network input disappeared after pressing the front panel selection button Now I have only 6 inputs left I can’t view my version either I don’t know what I’ve done wrong and what I should do next
Did you just do a firmware update? Please note that some options such as the assignment of a static can be controlled using mConnect as well as the screen.
Good. I assume you unpacked the new firmware to the memory stick, turned the DS Junior off, inserted it in the USB port, disconnected all cables from DS Junior (except power cable) then did a full restart from the back switch. Right?
So sorry. Then you need to try reloading the firmware all over again. please make sure you follow the steps in the readme file you have downloaded with the software.
F this does not work, you may try downloading an older version, the try again with the newest version (Sunlight).
