I will put this request on my list of thing to do, and see if it is feasible for the next release.
Dennis
Dennis
yacheah saidI can't answer your first question because of the answer to the second question. I'm a 40-year software veteran, and IMHO, the documentation for HQPlayer is among the worst I've ever seen. I could not get it working on my Mac after an hour or two invested, so I tossed it.Hi Is there anyone who is using Bridge II with HQ Player (preferably without Roon involved)? Does it work and is it easy to setup?Are there any benefits to:
using the HQ Player filter
upsampling with HQ Player since the DS DAC maxes out double DSD?
Thanks
Paul McGowan said Cover art is an important feature on DirectStream and the Bridge and we will continue to work hard on getting it as good as we can. Dennis is on it, it's not being ignored as you can see.We’ll get there and thank you for your comments and patience.
Also so thanks to Dennis for caring!
Any update on new Bridge firmware.
We are still working with our module vendor to work out the DLNA issues?
Dennis
Thank You Dennis.
I have the oppotunity to buy a second hand european ds and an us bridge ii. Do these two work together?
berlin
Yes Bridges will work in any country.
Dennis
Thank you! DS is one step closer to my wallet!
yacheah saidAccording to my experience, you cannot use the Bridge II and HQ Player at the same time. You may use HQP thru the USB connection of the DS, not the bridge.HiIs there anyone who is using Bridge II with HQ Player (preferably without Roon involved)? Does it work and is it easy to setup?
Thanks
Dennis Kerrisk said We are still working with our module vendor to work out the DLNA issues?Dennis
What are the fixes that’s in the pipeline?
The DLNA issues reported with 2.7.11, connection issues, volume control with Bubbleupnp.
Dennis
Hi Dennis
I noticed a Bridge test code update on the server.
Is this the code update you refer to above?
Have you deployed it to the test group?
Thanks.
This is 2.7.11. It is the update for Roon. If you are not using Roon, then you don’t need it.
Dennis
Dennis, prior to 2.7.11 what is the most recent Bridge firmware? I haven’t updated my Bridge II since I got it about a year ago. I’m not using Roon yet so don’t feel the need to go for the latest firmware, but want to make sure I didn’t miss something in the interim. Thanks!
For a DS or PWD it is 1.2.3
For a DSjr it is 1.2.5
Dennis
