Budget Power Cables
Gonna do an ac14 se mkii for the pre and an ac9 se mkii for the amp I think. Should run me around $225. I have about 9 inches to the rear wall, so should be able to make an easy bend. At least I hope so…lol
At least with AA if it doesn’t work you can send it back and try something else. Good luck.
Got the Pangaea AC9SE MKII and AC14SE MKII cables in, and I think I’m hearing better and tighter bass, and a slightly more 3d soundstage. Thanks for the help guys.
And @dawkinsj, man you weren’t kidding about the AC9. I got it in, but man is that thing a bitch to bend into shape lol
The AC9 reminds me a lot of the PSA AC12. Both excellent.
+1, if anything, the Venoms tend to sound smooth. These are my fave low cost cables. The later models provide better performance.
Here you have the world’s best power cables - they all hit them. I even make them myself, because you can buy plugs and cables
I would agree with the SUPRA. I bought two long lengths for speakers because I wanted something very well insulated to run alongside signal cables. They do two thicknesses, deepening on the needs of the unit.
Otherwise, Devialet supply their units with Audioquest power cables that they say are perfectly good. Many owners upgrade to another Audioquest at their chosen price point.
+1 on the “Better Cables”. Was using Silver Serpents and now have all Blue Truth. Very good bang for the buck IMO. This refers to XLR interconnects.
Regarding power cables check this out:
There are some DIY options which may be able to fit into your budget and also give you good results.
Great article. The comments section is a scream!
An example of subjectivity. I tried the Synergistic that he loved and I quickly sold it—at a painful loss.
No matter how much burn-in or wishing, it never sounded better than the stock black cord that came with my DSD Sr.
