Had this under “Uncertified Roon” but am getting no response:
Verified I am on Yale. I downloaded the Torreys DS Jr update, went through the install process (following the directions) and re-booted. Everything appeared to update normally. However in checking the FW I still have Yale. I have done this 6 times.
I have tried with both MAC/PC formatted USB drives. I have copied the zip file to the drive (seemed to update the FW) and the 4 files separately (did not seem to load the FW) - all with no luck.
I had previously updated the bridge software since Roon did not see the DSJ. Once I did Roon saw the DSJ but it was showing as Uncertified which was traced to not being on Torrey’s.
Could the Bridge update be causing a problem? Should I be re-loading Yale to roll back the bridge and than update Torrey’s? Could this be a hardware issue?
Would really like to be on the latest firmware to see what this equipment is capable of…
Are you sure the drive is formatted FAT-16 or FAT32? Not exFAT or NTFS? Also you need to use the OS eject function when removing the drive from your system.
Tried that 3 times. Also tried another full re-format of usb drive to FAT32. PeaZip extraction of the 4 files to the drive. DSJ blinked for 2 minutes. Loaded the software. Still Yale
