Has anyone hooked up a cassette player using the Analog inputs on the Sprout? I’ve been thinking about purchasing the Sprout but I wanted to know if anyone uses the analog inputs for cassette playing and how it sounds?
Cassette Player to Analog Inputs
devillears
#2
Two aspects regarding hooking up a cassette deck to the Sprout:
- You will need to use an adaptor (dual-RCA to single 3.5mm stereo jack) for playback (cassette output to Sprout analog input)
- There is no “Tape Out” facility on the Sprout for recording from Sprout
Apart from that, you should have no problems as the 3.5mm analog input should support a standard line level analog input.
Dave
