Sprout question
Can I hook up a cassette tape player deck to the Sprout at the same time as a turntable? If so, what cable will I need to connect the tape player to the Sprout?
Thanks in advance.
Yes. The Sprout has an analog in and an analog out using stereo mini-jacks. Assuming your cassette deck has RCA connectors, you would need a stereo mini-jack to RCA cable to connect the two. Two of them if you want to record. Note that the audio out on the Sprout varies with the volume setting so if you are going to use it to record you’ll have to remember not to change the volume on the Sprout after you set the recording levels on the deck.
Thank you sir. That’s good news. Loving the Sprout!
Glad to hear it. And welcome to the forum!
