I would like to create an audio channel strip (preamp-equalizer-compressor) all made by me and I would like to be able to reverse the order of the components (eq and comp, the preamp must always be at the beginning of the chain) can I do it with a switch? (pos1 EQ —> COMP pos2 COMP —> EQ) and if it’s not possible with a switch how can I do it?
I was thinking about relays but i don’t know how to connect them, does anyone have any schematic?
Instead I would like to avoid digital switches or mosfets.
I remind you that the signals are balanced so in addition to the ground there is a positive and a negative signal in input and output from eq and comp.
Thanks a lot in advance, happy holidays!
Massimiliano
