I have a Transparent Reference XL “Firehose”. It is sharply bent behind the DSS for room. It was working. I just turned it on and the DSS kept losing signal. I moved the cable and it works fine. I doubt it is a bad cable. It is most likely a connection issue being bent that way.
My question is, could this be ruining the sound. Or these either work or they don’t work?
If it is an issue, how can I tell if it is affecting the sound even if it is working steadily?
Thank you
