Constant flicker on my display-P-10
I have a constant flicker on the display of my P-10.
Should I be concerned ?
Have you completely shut it down including unplugging it from the wall and waited a few minutes before reinitializing it?
No, but then I realized I can just shut the display off. Which I did. The unit works perfectly…but hopefully I’ll eventually trade up into a 15 or 20.
A full reset of the power couldn’t hurt. Turning off the display was too obvious of a fix for me. Nice work!
