Dectet or Duet
Looking for something to put in front of my PPP to offer a bit of filtration and surge protection. Which one?
I don’t personally feel anything needs to be between a PPP and a great outlet. If anything, perhaps a PowerBase.
I’ll second the PowerBase. It does not provide surge protection but it does provide noise filtering and that ever important vibration control. I wish I could afford to put them under all of my equipment. It does wonders under the PWD.
J.P.
The Duet has been discontinued, the Dectet is now the current product.
If you can get a Duet easily and for a good price then I see no problem with using it. I think that it works almost as well as the Dectet. Not quite, but almost and certainly better than many alternatives.
J.P.
