Curious if anyone has used the Devore O96’s or the GibbonX with the BHK250. How do sensitive speakers tend to respond to powerful amps like the 250?
At least a couple of people here use this amp with DeVore Orangutan 0/96 speakers.
Powerful amps work with sensitive speakers just as well as flea amps.
Should be a good match as JA measured them 91 and 88 db. Lower than what John D spec’s them at. Same should be true of the new Super 9’s.
I had 096’s. I powered them with a 250 watt solid state amp and also with a 2 watt tube amp. They sounded sublime with both amps.
@RonP curious why you changed from the 096’s? What did you go to?
I had them on long term loan from a friend who was away for 10 months. They were magnificent speakers.
The speakers I own now and am completely happy with are Zu Audio Soul Supremes. The Zu’s are slightly more dynamic, which appeals to me. The 096’s are a bit sweeter.
