Finally, I got DSD Upgrade Kit from HK dealer and spent 1 day to finish installation. it’s great and happy that I can finish all the installation by myself…
After running the firmware upgrade process by using the attched SD card, the DSD start up again. I found the Bridge version shown up on the screen is 0.0.0.0. The bridge card I upgraded to version 2.6(upgrade-0.2.6.ub). Although the screen is shown up as 0.0.0.0 however, bridge can be found on DSD and worked. just only unicode cannot worked.
so … May I ask what should I fix??
should I upgrade the DSD to another version of 6115 and downgrade the bridge to version of 2.1.5?
yes, due to I have no 2GB USB memory stick, so all upgrade process doing via webpage.
first i find out the IP address using on bridge, then ip address on web browser, go to bridge webpage. finally click web upgrade and type the link on web upgrade page.
you mean version 2.6?? I knew version 2.6 and download from discussion forum
then i just only did a few tests on bridge. everything seems smooth especially play the audio source via Jriver. Jriver can find bridge very easy.
However unicode. seems not work. chinese characters are unable to read on DSD screen. this time, even ??? not show up. all are blank. tonight, I will try japanese characters can be read or not.
