Hello all,
Fedex just dropped off my new DSJ and I was delighted to set it up. I believe something is wrong with my bridge, straight out of the box, which is really concerning.
I use JRiver for streaming music from my office computer over the network, and controlled by JRemote on my iPad. I’ve used this system with my Hegel H360 amp, Auralic Aries and Squeezebox with zero issues.
Using the same system on the DSJ had many problems. Initially, Bridge would show up as a zone, then go away a few seconds later, only to reappear and so on. I’m not sure why but this issue repeated a few times and now seems to be stable.
Now my current problem. Any music sent over ethernet to bridge will play, however it sounds like the music is in a staticky tin can. I’ve tried other inputs like Toslink and Coax and these work. I’ve also tried using balanced and single ended RCA cables to my amp and those both work totally fine.
Is this a common issue, or something look wrong with my setup?
Best,
MSommers
