Thank you both for the pictures. It always good to see what other folks are doing. I may pick up a trick or two.
I’m curious why did you use indigo when the unit is 21lbs? Also, why three and not 4? TIA
The weight limit is for maximum weight I believe. I used four Indigos for my previous preamp and it was heavy. I found I like the sound with three better than four with MK2. Since I have one extra, I ordered two more Indigos to try on Pre.
Another flip phone user here. I use an ipad rather than a laptop so taking pictures is not a rapid process. My PWT sits on a Power base which sits on a P5 regen. Not sure if moving the base down onw level would help anthing but it would be a hassle.
But then how do you get to the forum on that?
I’ll bet he uses the iPad.
More of a joke than question.
Hahhaha. Got me
Ah thx. I’ve been struggling with pulling the trigger…3,4 go big or just right oh my! I think go big that way they’ll go under the unico 90 or the P15, PST or the Acoustic Signature Double X. There is the conundrum.
Hi @Paul,
Any update on the next MKII code update?
-G
Hoping to be internally testing it this week. Getting close!!!
That will be a massive early Christmas gift from PSA🕺🏻
Please pretty please, I’d like to see the update via ethernet cable option to be enabled soon. So I don’t have to do Yoga everytime I try to find the USB port in the back of the unit.
Donald, The SW6 is delivered yet?
There a lot to be said for this approach to life ![]()
It is scheduled to be here on Dec. 3rd. I have two BNC cables to tryout the clocks too. I hope I’ll not hear any difference.
If you do hear a difference, there are many Nordust BNC cables to try
