Is it possible to swap the sockets on a PS Audio DirectStream Power Plant 12?
An opportunity has arisen to purchase a brand new UK spec Power Plant 12 at a very good price but I use European schuko plugs and sockets throughout my system.
That’s only something that can be done at the factory and it is neither easy nor inexpensive. The entire back panel assembly has to be replaced.
Understood. Thank you.
Amazon must have 6” adapters to convert and avoid changing the Powerplant.
I switched to European schuko connections in order to avoid using fuses (we use fused AC plugs here in the UK) and so improve sound quality - therefore using UK to European adaptors (which are also fused) isn’t something I would want to do. I appreciate the suggestion though.
