Thank you scotte1. Great
Best regards
Lorenzo
I had this issue as well with Windom and straight USB into the DS. When I started investigating, I found that it was doing it consistently when the my PC/FOOBAR was moving from higher rez (24-192) to lower rez (24-96 or lower). It was during some testing of the Matrix after the Windom update. Normally, I use Matrix to AES/EBU with absolutely no issues, and prefer that sound much better anyway. I stick with that and donāt look back.
YMMV
Iām going to send an email your way with some files. Letās see if this helps.
Thank you Flip 49
best regards
lorenzo
Thank you very much Jameshā¦
How should I use them? I put them all on a single card and reinitialize by switching off and on as a normal sw loading?
Best regards
Lorenzo
Exactly. Use them like youāve done with the other loads. Then go into the settings screen and make sure Windom has loaded.
I did it⦠now itās working ( I checked on panel and windom is loaded ), iām already listening ā¦
let me check it keep working some hours without freezeā¦
Thank you very much James and to all for your support !!
Best regards
lorenzo
Please do. Iāll have my fingers crossed over here hoping it doesnāt freeze.
Hi James, my fingers was crossed too !!
Here the response:
For at least three hours everything was fine, then it stopped ⦠I reset and started working again, but this time for only an hour ⦠then freeze againā¦
Now here it is morning and I have to go to work, I will come back this evening and do some more tests (I would like to see how he behaved with redcloud) Obviously I will follow your every advice.
Thank you very much
Lorenzo
Lorenzo, sorry to hear itās still happening. I just sent you an email.
Hi James,
this morning I loades Redcloud before go to work, and itās still workingā¦
it seems a mystery ā¦
with Huron and Redcloud ok
with Snowmass and Windom Freeze ā¦
Can it depend on my windows 10 pc? ( it look work well) I use it to manage Jriver mc26, while the data is stored on QNAP on the network.
Thank you again
lorenzo
Hi James,
I can confirm with loaded redcloud DS is working without problem,
I will stop on this release for the moment ⦠i have not more ideas , but of course any your suggest is welcomeā¦
Thank you again to all
Lorenzo
Hi James, Hello everybody,
I would like to share the resolution of the problem inherent in the fact that when mounting windom or snowmass the Ds stopped after some time:
I have installed the bridge II and everything now works regularly, because I have removed the usb cable, that is, to connect my PC with the DS - now I donāt use the driver, this was giving me problems, and I tested everything on two differentiu PCs using JRiver.
I hope my experience will help someone,
I thank everyone who helped me to find the solution.
Grazie e un saluto
Lorenzo
