DS Snr - installing the Bridge II
Hi @tedsmith
I’ve just installed a new Bridge II. After installing it, the plate screw holes don’t line up with the DS screw holes.
If I push the Bridge II plate downwards I could probably line up the holes, to insert the screws.
But is it best to leave it as is, without using the screws? To avoid forcefully pushing the Bridge II card down and stressing the board?
Cheers
This has happened before and I think the consensus was to just leave the screws out.
