I see MK2 beta testing well is under way. A question from a current DS owner:
My setup is very simple: NUC (running Roon Rock) → ethernet → switch (connected to router) → ethernet → Bridge II → DS. I run Roon via Windows 11 laptop, two phones.
With “Bridge II → DS” disappearing when MK2 comes along, what exactly do I need to purchase along with the MK2?
I’d like to use MK2’s I2S input AND maintain ethernet feed (as switch is in my basement).
Do I just need a streamer and an I2S cable? I want to keep it as simple as I had it before. It’s almost like I just need to replace the Bridge II, no?
Suggestion of products would be nice. I’m sure I’m not the only DS owner wondering this.
Hi, there’s a smallish range of I2S via hdmi network transporters out there right now. The AirLens will be the natural complement to the DS2, for a streamer, and hopefully will be released either with, or very shortly after the DS2.
Some other i2s via hdmi network transporters out there include the:
If I connect my Roon ROCK NUC (via USB) directly to the MKII, I would not need a streamer I assume (?).
What would I be gaining by buying the AirLens instead and using I2S? What am I losing if I don’t bother with a streamer in terms of performance, Roon usage, future benefits, etc.?
Just wondering if keeping it as simple as possible is the way to go.
p.s. I was informed by a Canadian dealer that the AirLens is still a couple of months away.
