Hi all,
My DSD came directly from PSA with the Network Card II installed.
However, I may use a different streaming solution but didn’t get a blanking plate to fill the hole that would be left if I sell my Network Card.
Is this normal?
Hi all,
Is this normal?
If you contact PSA, I am pretty sure they would send you a blank/cover for the Ethernet card slot (probably at no cost to you - if I had to guess).
Yes, I have to call them. The DSD is brand new so I am assuming it won’t be an issue.
Also, I see pics of the network card having a USB port, mine doesn’t have a USB - is there a different version?
USB port was for loading SW. The new version is missing it.
Thanks good to know.
