Hi friend. I am happy with my new directstream dac cme with brige ll preinstaled and snowmas 3.05 sound great , but my only issue is not covert art on the display , how can do to see cover art on display? I read about put the sd card on the slot of dsd dac , this will be resolve the problem? The sd card that ps audio send with the dac can’t be use on this or other new blank as card ? Let me now about , thanks alfredo
Yes. Insert an SD card, gold pins facing up. Either the card that came with the DS or a blank card is fine. Smaller capacity cards work best.
Thanks for the info.
It is good to hear from you, Alfredo! It ha been a while.
Thanks. I am very happy with the sound of the directstream dac my next step will be the m700 monoblock.
El El vie, 15 de mar. de 2019 a las 9:34 a. m., Elk via PS Audio psaudio@discoursemail.com escribió:
