Hi, I have the Duet power centre. Up until now i Have only used it for preamp and sources. I read somewhere that it has a max rating of 1750W.I am confused to the 1750W max limit. I Would like to know if I can use it with my power amps and powered sub? Will my amps and sub use full watts , or during normal operation and listening levels would The power consumption be lower than the 1750w ?
2X 1000w Class D (monoblocks)
1x 300w Class D subwoofer
Paul, I currently have PS Audio AC5 feeding a Duet and then a pair of AC5’s going to my Primaluna Monoblock amps. Would you suggest replacing these 3 AC5’s with 3 Audioquest Thunder cables or going direct to the AC outlet with 2 much longer AQ Thunder cables. If I can get custom 4M Thunder power cables.
