Does the PWT play double layer DVD disk,s .
About how much play time on one of these disk,s , in wave format?
I have never tried it, but I am nearly certain the answer is “no.”
Oh . Wow . I figured I could just burn music on DVD ,s and use the transport. It is simple a reliable to pause and start. Do you know how much time on a reg DVD with wav files?
It depends, of course, on the sampling frequency and bit-depth of the files.
There are charts on-line which indicate the size of various file types.
Ok I see your point , even though the file type is wav the amount of data would be a variable .
Thanks I was not thinking clearly in this , thanks for the help.
