Eversolo stopped supporting their Qobuz app?
I’ve been listening to Qobuz connect for a while using A6 MA. I updated the firmware a few weeks ago. I went looking for the Qobuz icon to use the Eversolo Qobuz app last night and it seems to be gone now. There is an icon under apps but it seems to just take you to Qobuz connect. I like having the Eversolo Qobuz app available for its different sound but more importantly as a backup method when Qobuz connect is down. Looks like Eversolo may have stopped offering their own app and, if true, that’s a loss. Anyone else notice this?
Works fine for me on the T8. My A6 is not connected but it shouldn’t be any different.
I could have accidentally deleted the icon then. Maybe there is a way to go in and add it back. That would be great if possible to bring up the list of available apps. Anyone know how to do that?
As I recall with my month of trying out the T8, on the Music Services screen there’s a square with a checkmark in the upper right. Tapping that let’s you delete icons or add them back.
— Chris
Assuming my DMP A8 is the same just hit the edit icon and add it back to your list. I’m still seeing the native app but I also haven’t updated for awhile. I have had the list clear itself a couple of times. The SW has otherwise been pretty solid.
Thank you so much. Got the icon back and it was so simple.
