Nobo said
β-boys: is your silence the consequence of acoustic ecstasy coupled with enervation and resign after the testing process; or of resolution of all fundamental operational criticisms? May I be so bold as to gauge again where things stand along the continuum from gold brick to quantum computer:
DMP: seductive diva, frustrating but irresistible; or consummately satisfying mate, reliable and accommodating?
Seductive sound-wise? No doubt about it! Frustrating? Bet your booties! And the next firmware update (Dennis is working on one at present) will decide irresistibility for me. Two days ago I was back to having to repeat too many taps to the screen again for inputs to finally register. Dennis knows about my issues.
To play Redbook CDs, if used with a DS DAC connected by HDMI, does the DMP reliably do the following:
1. Upon inserting a CD, display the number of tracks on the CD and its duration, even better its title?
(Mind you, I still haven't connected the DMP to the Internet, so the information you ask about needs to be encoded on disks to display). Yes, the number of tracks always appears on the track-listing screen. Forget about recording-duration times. And I almost never see disk titles.
2. display the number of the track that is currently playing, or paused during play?
Yes.
3. permit changing to previous or subsequent tracks one per well-paced click, or direct navigation by numerical input on the remote?
Input the track number from numeric pad on the remote, and the DMP will take you there. Tapping the track-jumping icons on the screen, though, even if only to jump one track? Not always.
4. return to title page one, or at least track one to park after complete playing of the CD?
I will check on this for you later...
5. permit fast forward or reverse within a track?
Yes -- although getting to a specific play-point within a track is inexact. The quickest way is to tap the scrubber progress bar in an approximate vicinity of where you are hoping to navigate to, check the timing that appears with the new play-point, then tap again if you want to try to get closer from the progress bar...
6. open and close the drawer reliably?
Usually, yes. But just now, I tried opening the drawer from the screen after powering up a quite-cold DMP. (A longer story, but this is my first attempt to power-on the DMP when it isn't remotely close to room temperature). The drawer is clearly jammed. Will allow the unit to warm up for a couple of hours before trying again.
7. do all of the above by at least the remote, and ideally by the touchscreen?
Yes, but realize that taps to the screen do not always communicate and that the display does not always accurately depict what the DMP is doing at the time.
9. go into and out of standby when pressing the front button?
Yes. The only times when the standby button has not worked for me is when the DMP has locked-up. And locking-up is something it hasn't done since the last firmware update.
10. do so without locking of the software, adverse effect upon the DAC, or requiring rebooting from the back power switch?
Yes.
