Hi there, would you say that this AC 12 is genuine PS audio? I am going to buy it from a private seller and since there are so many counterfeit example I would appreciate your feedback. Thanks
You can’t tell from the image provided.
Information is here:
Is it possible to asses the originality of the cable by inspecting the box? Faked cables come with perfectly faked boxes?
It certainly looks legit but that’s no real way to tell. Counterfiters are good.
There were two grammatical errors on the back of the box of the fake I purchased, if I remember correctly. Unfortunately, I can’t remember what they were. You should be able to find the old thread on this topic.
The most obvious one is “conductiors” instead of the correct “conductors”
Here there are two pictures of the box. The spelling error is on the back (conductiors).
@Paul
So, I guess that there is no doubt; this is fake
Also why are there no check marks for the OFC conductors? That should have check marks on some of the lower end cables.
