What’s the difference between the HC and other outputs on the P15? Is it still the case that these are not regenerated, but only filtered?
Trying to decide whether my Devialet 1000 (class D, so relatively low draw for the watts output) should be plugged into HC output (I’m assuming no, if the HC are not providing full benefits of regenerated AC).
From the P10 manual, I don’t find any mention of the HC outlets in the P15 manual but I would expect the same applies:
All outlets are equivalent except that the three in zones D and E are labelled ‘High Current’ , because they incorporate in-rush limiting.
That’s right, and it should be mentioned in the manual.
Surprisingly, there’s no mention of the HC outputs in the P15 manual!
