Just tried to update my Bridge firmware.  The bridge is now lost, there is static and pops and attempts to reset the bridge via a USB and rescue don’t seem to be making any difference…
Any suggestions gratefully received…
Cheers
Gareth
Ok, think I’ve solved it.  Changing the DAC firmware to the previous version seems to fix the Bridge
Cheers
@gareth glad to hear you made it working again. Could you please comment which version you had and which did not worked out for you?
Thank you
