I updated my Bridge II firmware today and afterwards, my DAC no longer recognizes the Bridge II. If I check the setup page, is shows Huron firmware for the DAC and Bridge firmware as 0.0.0.0. Any help would be greatly appreciated.
I swear I am not trying to be funny. Have you tried turning it off and on from the back of the dac? I had to try doing it a couple of times and checking the software update and it sort of just started working.
So I removed the Bridge II from the DAC and let it sit for 1/2 hour and then reinstalled it. Still the same outcome. Guess I’ll be sending it in for repair.
OK, I’ll try that and report back. I have to get my PWD out from under my P5!
I'M having the same problem and trying to follow the instructions and hoping for the best... ...and it did not work, this after a few weeks of usage...
So, is this some weird coincidence that three Bridges have died in the last week? Must have been the eclipse - the gravitational lensing beamed a focused blast of neutrinos (how else could it have hit Sweden, too?) that mangled the Bridge’s electrickity thingies.
Mine’s back in Boulder now. I’m dreading the email from PSA blaming me for corrupting the Bridge by playing the new Taylor Swift song continuously for a week.
BTW, @juacif, my system was set the same as yours though my Bridge II was one of the second run of beta test units and considerably older.
thanks for the help, yes we need to check all possibilities and the network is one of them, however for me it sounds like a long shot for me since the PS Audio transport (or DirectStream Memory Player) is working and has full access to the LAN, see below, this over the same network configuration, but I will check that when I’m Back from work, late the evening 20.00 CET.
The current configurations as follows:
ASUS RC AT-3200, connected to internet
WUMC710_cisco connected to no.1 over WiFi
WUMC710_cisco connected to 3.1-3 by CAT5 cables
Mac_min,
DS Memory Player (see network details below) and
PWD DAC with a brand new Bridge II
3.1 and 3.2 network setup works without problem and has full internet access, naturally i have swapped the cables to see if one port was down but that is not the case
PWD DAC + Bridge II did work for 10 days ago but does not work any longer (no changes)
Unzip to a temp directory
Run mConnectSetup.exe
In the device list click on your bridge
Click update
Click choose file
Click on psaudio_0ug_mrt_v3.3.3_20170626.img
Click open
Click update
Wait 10 minutes
Click on refresh
When you bridge shows up you can reboot.
If you still cannot connect please message me and I can work with your distributor to get you a replacement.
thanks for all help!
I had some days with too much work, so I have been "off", nevertheless I have good news, for some unknown reasons it works again! (?) I hope that the Bridge II will continue to work :)
