Help OG DSD directstream vol over 50
Please help i may have forgotten what to do
Mk1 DSD dac
ROON o can not go above 50 on volume
All limits are Off
It will move above 50 then soon as you stop it falls back to 50 ?
Using as a pre amp.into a power amp
Rebooted roon PC etc etc so frustrating
I had the same issue a few times. I found that if I powered both the Roon server and DSD off. Not standby mode. Turn off the power switch on rear of unit. Wait about 5 minutes. Power the DSD back on. After DSD is back up, power on the Roon server. Sometimes had to do this twice.
Hope it works for you.
If you have a bridge II in your MkI, make sure to have it connected to LAN, even if not using it.
Sorry Guys I am a womble
You need to go on screen on the PS audio limit and in settings set a max vol there
all fine now LOL
