I noticed that there are 2 inputs on the sac. After repositioning my set and re-cabling - I did not get any sound from my system… Found out that I used I2S input 2, instead of input 1 as used earlier.
I suppose that either input is OK? I was happy that I managed to get things working after re-directing this on the DAC screen. …
You can use either of the two I2S inputs as they are functionally identical. You just need to select the proper input on the touch panel or via the remote.
This means that you can add an extra PWT Just for the fun of it…
Is there anyone that does not?
