P10s can be stacked, yes. They rarely get hot enough not to.
A P20 is something I’ve often dreamt of - but there’s just no room in the chassis and it would have to get enormous. Maybe that’s not bad?
The other problem with a P20 is where do you get the extra juice? Right now the P10 will give you everything the wall has to offer, less about 15% to run it.
I understand the chassis would need to be bigger, would 19"x 5 RU be enough? A lot of devices are that size already, but it breaks the Ps Audio standard ;o)
Or what about dropping the low power section altoguether, or having less outlets in that section?
I am in Europe and we can have 16A outlets on 2,5mm2 wire (close to 13 AWG), for the 22V network. That allows 3520VA to be drawn.
The specs of the P10 say 1500 VA, is that by high power outlet or for the 2 outlets combined?
Thanks for answering about the stackability of the P10, something I will look at. A pity to have 20 outlets when I only need 4 though!
I believe the only difference between the high current and other outlets on the P10 is that the former have inrush limiters for when you first turn the amp on. After that all the outlets have the same output capacity. (Hopefully someone can confirm that.) The other option would be a good quality power strip (not my first choice).
