Is it safe to connect the AirLens to the DAC using two signal cables simultaneously?
Hi to all you Hi-Fi enthusiasts :slight_smile:
I have a question for you all.
I’m hesitant to try this without asking someone who might know! Can I connect my AirLens to my DAC using both I2S and Coax connections simultaneously—meaning, is it okay to have the AirLens and DAC connected via two signal cables at the same time? I’m planning to compare the two connections and, for convenience, switch between them using the DAC. What do you think? Is it safe to do that?
BR. Allan J.
Yes, you can do that without problems of any kind.
I too can confirm it can be done. Been doing it for a year or more without issue.
Just be careful of what you ask for with your three wishes when the genie appears.
Thank you for getting back to me with an answer to my question. I appreciate it.
Best regards, Allan J.
I also want to thank you for your replying.
Thanks for the reminder! I’ll be careful what I wish for :slight_smile:
