Is this amp a dead-end?
Hi,
I was interested to get this group’s opinion.
Is this amp a dead-end? Meaning, i cannot find any schematics/specs for the potential replacement parts needed to rebuild it someday.
Would a good amplifier repairman be able to repair this amplifier if it had need for caps, powersupply, etc?
As you probably know, that was built in a one man shop using lots of proprietary circuit boards and design. When the owner/builder died all support vanished. There used to be quite a bit of discussion and info about these amps on Audiocircle.com but all threads/info have vanished from the site it seems.
Thank you. Yes, that is what i have read as well.
To be clear then, an audio repairman would NOT be able to repair this amp as it ages?
No, that was a proprietary design and family members have had no interest in releasing schematics.
Thank you for this information.
It is sad this design is no more.
Several techs reached out to the family but got no reply. Tommy had no plan at all.
I’d be careful, class-D amps are fussy with digital RF based designs and can be a real problem with RFI emissions if not repaired and done correctly. The good news it should run just fine for a long time. My APT 1 amplifier made it 30 years! If you like it, no reason to worry about it as you’ll get your use out of it more than likely.
Galen
Same thing happened when the designer of Spectron amps, John Ulrick died. No more support or parts.
