Just Received New 12AU7s-Apos Ray & Psvane Horizon-They Look Identical
I just took delivery of a matched pair of each of those tubes. Other than the gold pins on the Apos Rays, they appear to be identical. Hmmmmm… At $207.00 and $60.00 respectively, I can’t wait to compare them in my BHK Preamp for any audible differences. I’ll be doing that later today and will post my findings. I’m hoping the Psvanes sound just as good for 1/3rd of the price. If so, the Apos Rays are taking the long road back to China.
I had both tubes in my BHK. The Apos Ray tubes were much better to my ears, when I ordered them last October they were $180. I thought they were easily worth it. Good luck!
When I had BHK Pre, Apos Ray 12au7 easily outperformed the stock Psvane too.
Dchang05 & softlight64, what version of the Psvanes did you have…the Art line, or Horizon line? The Art line internal structure is visibly different from the Horizons, with the most obvious differences being the plates, insulation spacers and connections below the bottom insulator spacer. They are a completely different design. Psvane claims the Horizons are new and improved and were introduced on May 28, 2024.
In what way were the Apos better?
I just went back and forth a number of times comparing the Apos to the Psvane Horizons and without any burn in time yet, I don’t hear a difference. However, I compared them to a pair of burned in Art Psvanes and they do sound better than the Arts.
I’m going to burn both sets in for a while and then do another comparison.
From Psvanes Website:
" * With an enhanced internal structure design, our 12AX7-AT, 12AU7-AT, and 12AT7-AT tubes have significantly improved performance, achieving industry-leading minimal noise and microphonics. Thanks to an extensive pre-burning process, these tubes deliver exceptional performance from the start, ensuring an extraordinary auditory experience. Experience the difference now and enjoy unprecedented clarity and detail."
" * It has tonal density with a strong and full flavor. The bass and mid-range are full and smooth, well-balanced, and good overall performers with a high frequency extension and good separation. It maintains excellent composure, never losing its cool, even under complex and messy mixes."
I don’t know which line my PSVanes were, they came with my BHK. The Apos Ray tubes were better in every way, not close.
They were more than likely the Psvanes prior to the Horizon collection.
Well, I burned in both sets of tubes and did some critical listening. I also had an audiophile buddy over to listen as well. The bottom line is that we could not hear any differences between the Apos Rays and Psvane Horizons. We swapped them in and out about six or seven times, but never heard the slightest difference in timbre, imaging, sound stage, instrument separation, dynamics, bass, etc. Luckily, Apos allowed me to return them with just a $10 return shipping fee.
I have a very revealing system, consisting of an Airlens endpoint, Direct Stream DAC, BHK Preamp, BHK 250 amp feeding Magnepan’s new 3.7X and two REL T7i Subs. Speaker cables are Wire World, DH Labs interconnects and an AudioQuest Carbon HDMI out of the Airlens to the DSD I2S port. I was streaming to the Airlens via Roon
I studied the structure again of both tubes closely, using a magnifying glass under bright lights. They look identical, other than the gold pins on the Rays. So, if you’re going to put some new tubes in your BHK preamp, you might want to snag a matched set of Psvane Horizons on Amazon for $60.00, rather than dropping $207.00 for the Rays. BTW…Psvane even provides a 1 year warranty.
Thank you for the outstanding review. PSVane has a number of “collections” (Art, ACME, Horizon, etc.) Is Horizon the one to get vs ACME for instance?
tomhail…Yes, you are correct. These are the Horizons. I believe the old Psvanes that came with my BHK preamp were the Arts, which have a different internal structure. I’m pretty sure the Horizons are the newest “collection”, as Psvane likes to call it. They were released in late May, 2024.
I have the Psvanes on order
Thanks for the review of the tubes.
You’re very welcome. I hope you enjoy them!
Since the Psvane Horizons are avaiable on Amazon I will try them next time and compare them to the APOS that I have.
No risk with 30 day return policy.
Thanks for the review. I just ordered the Psvane Horizons. It was good timing for me as I am very close to changing my tubes in my BHK-Pre.
How long ago did you purchase your Apos Rays? I’m just curious if they’re the rebranded Horizons, or if they had previously sourced a different tube? For all we know, they could have been rebranding the Psvane Arts at one time.
Cool! I hope they work for your.
I purchased them used from a fourm member a year ago or so. So not sure on the exact date of purchase.
Good to know, thanks.
I bought a pair of Apos Ray 12AU7 Tubes this past September. When I turned my system on this morning (through a PowerPlant 12) my BHK Preamp started giving me a loud click through my right Magnepan 1.7i. Suspecting the tubes, I switched sides on them and it was definitely a tube causing the problem. Of course, the APOS 45 day warranty has expired and I am stuck with a defective (and expensive) tube…
45 day warranty? Their website currently shows a 12 month warranty.
“An exceptional 12-month warranty rarity in the world of vacuum tubes, especially NOS vacuum tubes reflects Ray Tubes confidence in their vacuum tubes performance and durability. This warranty is your safeguard against any manufacturing defects, making sure that your investment is protected.”
Thank you for clearing this up for me. I just sent them a message requesting a replacement for my 4 month old tubes.
