My comment is purely from memory, so I stand under correction.
The P1000 is a much older design, and terribly inefficient. It will run hot, and it’s doubtful if it can be cheaply repaired when it fails. It’s also BIG and heavy.
The P3 is a much newer design, and much more efficient. Once again, my recollection is that it has limited regenerative capacity - so you’ll be looking at perhaps a DAC, Transport and/or Pre-Amp. Fortunately, I THINK (not sure) that it also has filtered, unregenerate outputs. So this model can be seen as a “one for all”, despite it’s lower regenerative capability.
My two cents; anyone please correct me if I’m wrong. My preference? The P3, no doubt.
Edited to add: I think the P3 shared the same tech with the P5 and P10 - even the later P20. Again, I could be wrong. I also think it had a relatively short life. Personally, I could never understand why it was discontinued: I’ve always seen it as the first model that you could connect even a massive system to, only regenerating some of the smaller draw items. In a country like mine, with our fragile power grid, this is important.
But all of the above is now only a distant memory, thus may be heavily flawed. Speaking only for myself, I’ve sold my P20 and bought a “measly” Transparent PowerWave X (conditioner only), after the P20 proved incapabable of driving my Aurender AP20 and Aurender NH10 Network hub.
I concur with what’s just been said. I use a Stellar P3 for low power stuff and P10s for stuff like power amps. I once tried a Premier and considered it a waste of time. The proper P3 should do a good job IMO (this older generation does sometimes degenerate and require it’s boards to be replaced but as long as it’s working correctly it’ll do a good job).
Again, speaking only for myself: I’d advised against.
The PPP is far less capable of correcting voltage swings as I recall.
If you are getting a steady voltage of 110V or 230V, then fine. I think.
Also, I doubt that they are supported any more.
A P5 or P10 in good nick is better value.
