Hi
Presently using a Linn Selekt DSM Active into Linn 119 speakers with Kudos KS-1 speaker cable (5m length).
I am considering using a four core cable instead of 2x two core cables and as per the title, has anybody compared the above speaker cables.
Reasons for changing;
- The DSM runs warm to the touch, not too warm to touch, but warm nevertheless. Checking the resistance of the cables is as follows; Kudos 1.5mm2 = 0.03 Ohms / VD 2.5mm2 = 0.0076 Ohms / VD 4mm2 = 0.0046 Ohms. Does the cable length and thickness make a difference
- Would like 1x four core cable instead of 2x two core cables
- Change cable colour to black from white for aesthetics
- Due to repositioning would need only 2.5m length instead of 5m
Thoughts would be appreciated
Cheers
DG…
