I am looking for a music player app for the iphone to play saved files similar to how an ipod would work. Ability to create playlists, play be genre, etc. Any recommendations?
I use KaiserTone.
I used VOX for a while, had excellent reviews and handles FLAC files ok:
VOX – MP3 & FLAC Music Player on the App Store (apple.com)
Has a Mac app also in case that’s of value.
@SpyderTracks What are you using now i.e. if you are using one?
I’ll check both of these out.
I now use Plex, for mobile use I find it perfect. A lot of people quaff at the quality but I find it really good. And means I can stream off my own personal cloud which is convenient.
I’ve tried Vox and it sounds bad to me. Lifeless mid scooped sound.
I recommend OnkyoHF.
