New SVS HDMI Cable
Hmmmmm:
FYI and comment.
(I will probably update [upgrade?] some of my less-critical, older HDMI cables with my A/V kit with a few of these cables.)
Certainly less expensive than AQ Dragon and other “mythical beast” ones. =)
Just a quick heads up . Blue Jeans Cable stocks new “Certified” HDMI 2.1. Do yourself a very big favor and least take a look and consider
 Series 4
I like SVS Subs and products but at $30 I’m pretty sure it won’t slay any Dragon’s.
Do you use BJC Series-4 HDMI cable? Doesn’t seem to be anywhere near as popular as the Series-FE cable? Why might that be? I suspect it’s simply because users are reluctant to order it fearing that’s it’s so thick and stiff that it will strain HDMI connectors. Indeed, I emailed BJC two weeks ago to ask about diameter differences between the Series 4 and FE cables but no answer. . If not BJC what other HDMI cable for my Oppo 203 BD player? Please advise.
What is your budget?
