I picked up a used Stellar Strata.
I get no audio out left side, when I am using any of the analog inputs. The coax digital in works just fine.
Any troubleshooting ideas?
Firmware 2.3.0
Firmware 2.3.0
Welcome!
Switch the left and right analog cables and see if the sound switches sides.
Also check the “balance” control is set to the middle and not one side only.
I did do that. Swapped audio ins/ still only right side. Checked with headphones too.
Checked balance/ on zero.
Plus works fine digital coax in
Thanks for ideas
This may sound rudimentary, using the remote control try rapidly switching back and forth between inputs. It worked for me when my Strata was new if an input didn’t work properly. After a few times the problem disappeared.
Hope it’s just lack of use.
Update: I sent the unit into PSAudio for repair.
