I listen to your sample recordings of Otis Taylor. The music is great but the samples pieces are cut off at around 8K and above. Is this just the samples that are cut off?
Welcome!
Yes, the samples are bandwidth limited making them fast and easy to load. The actual recordings are full range DSD.
Elk’s got it. The samples won’t be super high res as we want them to stream quickly. Samples are meant to give you a taste of the music.
