One last turntable
I am at the time in my life where I only have time for
Purchasing one last turntable
And enjoying this last turntable
What would you recommend? I check on the market for the last two week and I am more puzzled than certain about what purchase?
Budget 2K, I prefer investing more in the cartridge
Something that managed well with shaking hand, So no bouncy Linn!
So what would you recommend as your last turntable???
I would have suggested the Technics SL-1300, but it’s 2x your price target. It’s a great table for the money, though. You could maybe find a 1200GR2 for about $2K, but at that price I’d also suggest a Rega (I guess a Planar 6), or a Clearaudio. The Project X2 B is interesting in that it is natively wired for balanced output, which is nice. These are all new; if looking at used tables the options open up quite a bit.
Thanks no more use
Uturn or fluance are they good?
I have no experience with either of these.
Are you talking 2000k US or CN? If I was looking in your price range for a well built trouble free TT my first choice would be the Technics SL-1500. Don’t know anything about Canadian pricing or dealers as the few I’m familiar with don’t carry the brand.
This is a link to Canadian dealers from the Technics website.
https://www.technics.com/ca/where-to-buy.html
Here is a dealer with it priced at the same as in the US.
the auto lift is tempting!
Also the SL1200 regular, will be available by the end of october in different color for the 55th anniversary or the sl1200, but no autolift!
use to have the 50th anniversary, but sold it, didn’t like the DJ look, but 1500 more like it…!
Fluance also have a stop at the end of record the 85 modele, that was praise by guttenberg!
I would stick with the long term durability and reliability of Technics. There is a reason that many of their TT’s are still running without issue 50 years later. Plus if you are a fan of Grado cartridges they are a perfect match. Vintage Grado Signature bodies with current production Signature styli have been in regular rotation in my system for years.
Big fan of Denon 103 and the moving iron principle of Grado, that let you play with the curve! presently a green; black and sonata + my 103. I always came back to those!
I have a full automatic, but for strange reason, I have current that comming back to the RCA, small short, when i touch it with my finger? my tube amp or my TT, I am still trying to figure it out…!
a friend, will pass by with his technics, so we will know if it’s my old revolver the problem!
So that’s why the search, for one final turntable that will keep me company to the grave!
Listening now, an old 1700 technics! very impressive!
Strange, it got a suspension isolation (sort of) on it and it is direct drive.
Good match with my Denon!
Btw, there is a new 1500, that was out in may, so maybe good deal on 1500 to come!
That link I sent you earlier to the Canadian dealer with a price the same as the US price is likely the lowest you will find the 1500 in your country. The standard price for the table in Canada is $2000 Canadian.
Yup, i saw that
Last version SL1500 CSP is 2000$, but old version C 1599$
Regards
I am not sure what improvement they made in the two version but it’s 400 more you have to pay!
Maybe the C model, We have some discount in the near future
GemDandy PolyTable Signature by George Merrill with a DS Audio Optical Cartridge. Best you’ll ever hear.
its a little higher than your budget but I have a Raven one table with the coveted full brass arm plate. It would need a graham arm, but it’s an incredible table and very compact
I have no experience with UTurn. At our little shop, we usually carry the Fluance RT81 because it’s a nice budget point for value. However, we’ve also had the RT82, which I remain impressed with after an in-house demo, and I usually recommend it to serious listeners on a budget. The Ortofon OM10 cartridge that comes with it is better than most at this price point, but if it were my table, I’d upgrade the platter mat and cartridge with the remaining cash of your $2K budget. We’ve had zero returns and zero customer complaints about the Fluance tables.
the autostop on the RT85 is interesting to!
since technics 1500C, is presently not available, I will test the upper one that was out in may next.
there is also a store that will close in october in montreal, and he has top of the line thorens 1600! beautiful rosewood, but bit over 2k$ and no autostop…!
Wife and me like auto stop, Wife because she forget it, and me because wife sometimes start reading and forgot it to! (that could be an interesting thread, “do you let others use you HiFi gears”)
Testing:
A lot depends on what phono preamp you have or plan to buy. Given your budget I’ll assume a MM cartridge. I would look at the Rega line probably a P3/RP3 and that Denon 103 cart is supposed to punch way above it’s weight. I’ve also had good luck in the past with Ortofon Blue cart.
You might also consider a Rega ND3 MM cartridge ($345) which uses Rega’s 3-point mounting scheme. It makes cart installation a breeze.
Rega P3 is an easy recommendation as is their entry level phono stage.
