P 10 Voltage Change
Hi All,
I wonder what is involved in changing voltage from a P10 unit from 110 to 220V? I would like to know if it would be possible
to program the P10 to give me say 5 out lets with 220V and 3 with 110?
Thanks.
Unfortunately that can’t be done. 120 and 230 volt units are physically very different inside.
Paul,
I found some P10 in US area, the rear back left bottom part has a mark Fuse, both 120v T250v and 230v T250v. What is this version? Asia or US version or 120v~230v international voltage? Can it be changed the input voltage to 230v easily? or it never be changed from 120v to 230v, the transformer inside only has 120v input or the transformer has both 120v and 230v input?
<img src=“http://www.psaudio.com/wp-content/uploads/2014/03/P10-rear-new-2000.jpg” width=“800” alt=“P10-rear-new-2000.jpg” " />
The P10 cannot be converted from 120 to 230. It takes different componentry inside and can only be rebuilt at the factory.
