P10 Zone problem
Has anyone got problems with Zone C on their PP?
I have set it to Always on and the web GUI reports everything healthy (green), however both outlets are dead.
When moving the load from Zone C to Zone A, everything works.
Sounds like you may have a dead relay or bad solenoid connection to it for zone c. Sounds like it may have to go back, unfortunately. Does the front panel show the outlet for zone c in the ‘green’ (i.e., turned on?) If so, there’s probably a hardware failure somewhere along the line.
Best of luck.
–SSW
Sounds like you may have a dead relay or bad solenoid connection to it for zone c. Sounds like it may have to go back, unfortunately. Does the front panel show the outlet for zone c in the 'green' (i.e., turned on?) If so, there's probably a hardware failure somewhere along the line.
Best of luck.
--SSW
Thanks.
Yes, it is green and doesn't report any problems of any kind from what I can see.
If I don't need it I think I will wait a little with the return, still if it is a warranty issue.
@frode
Let us know how it turns out for you. We just bought 2 P10s; one for the stereo and another for the Home Theater system.
Good luck.
Bob
